Good day.....well bad day really. My reg/rect failed its test. No magnetic field at rotor/stator area, no voltage at brushes and continuity test failed on device itself. What have most be buying/ building for a replacement? I have read a few posts about a VR 38 and radio shack 3ph rectifiers. Is this the route most have taken? Your wisdom is appreciated.
Ohh my bike is an 83 with stock ignition and charging. New Shorai lithium battery and new rotor with 4.7 ohms. Stator has 0.8 and all white leads if that helps. New wiring all around the bike with LED headlight tail light but regular turn signals. All grounds are good and sound.
