DustyR
Hey guys, I know I've got other active questions going on right now but I've been sitting here reading about wiring and ignitions and had a NOOB question. I have an 81 xs 650 special. I want to go to barebones wiring and eventually wire everything new myself. I'm experienced with electronics but not necessarily with this motorcycle ignition. Being an 81 I assume that my ignition is electronic, meaning there are no points. There are no wires leading out of the side covers and although I have not taken the covers off I suspect there is nothing there. I want to make my own wiring harness and run only a headlight and tailight. I plan to retain my full size battery and also keep the electric start in all its glory. With that said, here is where my confusion begins. I have read about many different ignition systems on this forum. Can I or would it be wise to retain all the stock ignition components and rewire them using the minimalistic approach (ie, eliminate all the relays and switches, etc) also would I need to keep any of the relays, such as the ones that shut down the starter circuit after so many volts are produced by the alternator? I would ultimately like to put all the electronic components in a faux oil tank like many of you guys have done but I don't know what exactly I can eliminate with this bike having an electronic ignition. Do I need to buy all new ignition components to have a small enough package to put it all in the oil can? I have looked at the boyer system but do not understand it... The pictures showed putting some sort of system in the points cover? I hope you guys can help me understand what I need to do here.
Dustin
Dustin
