81' parts compatibility
gbftats7
CA
Hello, I purchased an 81' xs650 motor. Its missing the camshaft and all the guts from the valve springs up. It seems more cost effective to just buy the top end with the cam and components rather than fishing on ebay piece by piece. Im curious if 74-82 will be compatible? I saw an 81 top end, but the 4 bolt cover has a different pattern than mine. Any help would be appreciated
Yes. No changes in those years that affect interchangeability. One thing to watch for is the numbers on the head and rocker box need to match. The cam journals are line bored as a set.
thanks for the info, i'll take a look at mine in the morning.
The one in your picture, is that yours? The top cover is on backwards, lol. That's why the pattern on the 4 stud valve cover is off. Also, that head is older than an '81. The "tell" is the little nubs or protrusions on the ends of the rocker arms. They were there for the compression release to act upon on the '72 model, but were carried on into '73 and maybe even '74 even though the compression release was removed. I guess Yamaha had a lot of them to use up, lol.
Yeah, if that's the sellers photo I'd be a little wary.......
ah thats better! i just slapped everything together when i picked it up so nothing would get damaged, the alignment pins were in the wrong locations.
As mentioned, the head and it's top cover are a matched set. There are numbers stamped on the front of both so check yours and make sure they match .....
