81 XS 650 lost spark more question
oldcoal
Missouri
Ok so I post back a week or so ago about lost spark. Battery is charge but have no spark even when you turn it off and on. Also have a problem with the neutral switch as in it seems to have stopped working so the starter will not work either.
So can I check the coil like I would a car coil by hooking it up to the battery then unhook one wore to see if I have spark when I do that and if I can does it matter with wire goes to the + and -.
On the neutral switch is it a wire that if I unhook it would that make it so the starter can be used or does it ground to make it work??
I do not ride much any more but would like it to at least be able to be rode
Thanks
