91 Octane build
DirtyErnie
Renaissance Hick
Mound, MN
Looking for tips, spitballing a rebuild with new pistons. We can get 91 octane non-oxygenated/ethanol free gas is a lot of places, so I'm thinking about high compression for 91.
I have a Hoos Racing Shell#1 cam, and a stock cam on the shelf.
What sort of compression ratio should I be looking at on either a 650cc 1st Over, or a 700cc overbore?
Thanks!
Off Topic, in Kalifornia you can get 100 octane for just under $9/ bucks a gallon.
I usually aim for 9.3 - 9.7 CR, that's running 95RON here in Australia
My Evo BT is also set up @ 9.7 and I run 95RON (and sometimes 97RON) in that, I have used 91RON it in once and it detonated badly.
My 2c would be to keep it around 9.0CR as already suggested.
Running the shell #1 will also help with keeping the CR under control and minimising the detonation.
Goodluck with your build.
E85 is about all we can get around here that's over 91 (R+M)/2. What's that stuff supposed to be, 105? Same blender pumps put out E30, allegedly about 93-94 octane. My FFV F-150 gets the same mileage on that stuff as our state-mandated E10, and it's quite a lot cheaper...
... Not that I want to run any more ethanol through carbs on a street bike.
Thinking of 700cc 9.5:1 would be the easy path.
