A bit of History "Pops" Yoshimira
An interesting tidbit in the GS tech part may have relevance for the XS650. Bonus points if you guess what I mean!
Let'see...you want to grind your cam chain adjuster so it only contacts the rollers...
Not sure what else it could be unless you're dreaming of 135 hp. Can't be that...
Thanx for the trip down memory lane. We used to sell Pop's stuff, including his 4-into-1s. I'll never forget watching him hand grinding racing Honda 70 cams. Always wondered what happened to him after 1975.
On your 'relevance to the XS650', my best guess is the polishing of the camchain link edges, something that's been on my 'wanna try' list...
Something like this. XSjohn pic, he was doing it to his cam chains
Honestly when I posted I thought sure too many would get it, but not yet.
Hint; it's not cam chain related.
lots of neat ideas there .
Haven't finished reading the article yet but my guess would be
Steel clutch carrier instead of aluminium ? to prevent plate tangs cutting into the ali carrier teeth and thereby reduce clutch drag ?:)
Undercut gear dogs for more positive engagement is a neat mod too
How about the folded clutch plate tangs ??......are we getting warm
Does the winner get a trip to the Seychelles ?:laugh:
Maybe but it won't be you. Keep trying guys. The mod is not too far off in an odd corner, I think it affects a (more than always realized) common XS650 issue and a rather unique way to deal with it! Bonus it's something that could be (should be?) done by the serious home builder.
Well, I was trying to remember the name of that 'heat conducting' paint used in the `70s. The article talks about aluminum-oxide blasting and Kal-Gard coating. I believe that may have been the paint I heard about, remembered something about military applications...
I saw that bit but my thinking was as a DIY builder I would install an oil cooler first which would be much more efficient in cooling the engine.
I guess it has to be something that would be relevant to all of us because if it was a racing mod it probably wouldn't be very relevant
What are the most common XS650 issues that effect us all ? clutch, gearing, handling and for part of the World over heating perhaps. what else ?
Without having the time to read it all the way through (leaving to go back to Texas for good tomorrow), I'm going to guess lateral bracing above the swingarm pivot.
No joy yet.
OK big hint crankshaft.
Maybe it's me in the wilderness? (again)
Ok, got it now. He beefs up the crank. You bent a crank. We had to dig hard to discover it was actually a motor that you'd 750'ed.
Yes the use of some sort of anerobic glue when pressing the crank together. I have a crank that got loose enough to wobble, I haven't opened it yet but I would bet the RH con rod pin is where the problem lies, it's not a 750 it's a stone stock 650 with about 20K miles. I put about the last 1000 on it without issue or serious flogging. I also have a 750 kitted motor that has developed a bottom end "whir" I'm guessing a pin is moving in that one too. Several others have heard that dreaded bottom end whir which I think is either bearings being heavily loaded sideways or the crank starting to mill the crankcase.
I think I remember a video of yours where the crank was obviously wobbling. I was following those 'wirring' threads too because mine does it, but only if the temp is below about 40 and only for a few minutes until it warms up. And not really loud. I told a mechanic I know who's worked on these full time all his life and he said it can come from a crank bearing with a pit, But he said it wasn't that in my case because it would do it all the time. It's been two or three years and it's not changing, so I'm not very concerned.
The same guy, once I told him had to replace the diode inside one of the relays and I started to tell him what the symptoms had been, and he told me what they had been before I could! That amazed me. Especially now, since I can't even remember for sure what the symptoms were myself.
It should be easy enough to drop the sump and measure between the flywheels on both sides....... want to do that on several cranks I have to see if it will allow a simple oh crap the pin is working loose diagnosis. Yamaha's race guide talks about the pins, says if less than 20 tons is needed to press the pins in they are too sloppy for race use...
That glue could be interesting stuff. The way I read it, implied it had to be done at the factory, presumably with special alignment fixtures to avoid the whacking necessary to align it...
