1. Dismiss Notice
    Dismiss Notice
A lithium battery DIY experiment.
Discussion in 'The Garage' started by gggGary, Oct 1, 2020.
  1. bosco659
    bosco659 XS650 Addict XS650.com Supporter
    Interesting. Might make up a 12v battery pack for my workbench to use for testing projects and other stuff. Went on the website. Which batteries are these that you used? Thx!
  2. gggGary
    gggGary I'm listening, change my mind XS650.com Supporter Top Contributor
    You will have to watch, when these came up I grabbed them, they sold out within the day.
    https://batteryhookup.com/products/...4&_sid=046a22d3a&_ss=r&variant=28616328413263
    Battery Hook Up is an interesting start from nothing, business story.
    We went rock climbing instead of taking the bike out yesterday, simply spectacular October weather. Today Allison and I are doing a fall ride on the road sofa. I do have a "full function" LIPO battery charger from when I had the EBR with a lithium battery. I cranked ole' Madness to life then shut it off several more times yesterday so this battery is showing to be reasonably tough.
    Thinking of putting 4 digital voltmeters, one to each cell, up on the bars.
  3. bosco659
    I like the screw terminals. I’ll have to order a set. Thx for the intel on these.
    Jim and gggGary like this.
  4. Mailman
    Meanwhile, out in Gary’s laboratory............Stand back! This baby has 500 gigawatts! :laugh2:
  5. JRay77
    JRay77 XS650 Addict
    Haha! Flux Capacitor!
  6. gggGary
    25 miles and all is well, battery now showing 13 volts bike off. Two volt meters one from cluster one direct to battery tender wire, it was possible to see the battery charging taper off after about 10 miles, the numbers converged then crossed with battery voltage being higher at the end of the ride.. Afterwards battery cells were no warmer than the surrounding frame etc.
    the youtube video of a guy starting a V6 car showed significant voltage drop under starter load. I'm seeing a bit of that also. Will investigate a bit more after I am confident the cells are fully charged. I have enough bus bars to double them up. so may see if that makes any difference. 20201009_181354.jpg
  7. MaxPete
    MaxPete Lucille, Betty & Demi - I suggest but THEY decide. XS650.com Supporter Top Contributor
    Sounds great Gary....but I would still keep a fire extinguisher handy.
    GLJ and Jim like this.
  8. gggGary
    I'll continue to drink lots of fluids.............;)
    PS both voltmeters stayed below 14 volts. Batteries are rated for 14.6 volt charging @80 amps I suspect the XS alternator will keep "a bit" below that.
  9. xjwmx
    xjwmx It's just the unknown. Top Contributor
    7,395
    3,486
    313
    U.S.A.
    Looks like enough room in there for JRay77's tongue condoms
    Paul Sutton and gggGary like this.
  10. buzzword
    buzzword XS650 Addict
    sport or trad climbing? can’t see the entirety of your gear rack in the pic...
    either way, awesome. I haven’t been on real rock in years - probably couldn’t properly flake my rope if my life depended on it at this point.
    gggGary likes this.
  11. gggGary
    Just top ropers for the last few years :rolleyes: Devils Lake, a midwestern climbing mecca, is 3 miles from the house. :)
    Paul Sutton, arcticXS, Jim and 2 others like this.
  12. gggGary
    Bought 4) 3 wire digital voltmeters, thinking of using an RJ45 connector at the battery for the voltmeters so the battery remains easy to disconnect.
  13. Paul Sutton
    Paul Sutton Still Looking Good Top Contributor
    Li Battery Fires: From what I have read these fires are caused by charging at temperatures below 0 Celsius. During charging the Lithium is absorbed into the electrodes but this process becomes inefficient below 0 Celsius resulting in Lithum building up on the electrode surface and shorting through the insulating membrane to give...
    [​IMG]
    TwoManyXS1Bs, Jim, Downeaster and 3 others like this.
  14. gggGary
    Hate to report this, but all things are not balm in Gilead this morning.
    Switched handlebar voltmeter shows 13, that's good. Iggy on, hit the starter; click, all the lights go out.
    then they come back on. rut roh. repeat, same result. Fuggle around, remove, double check everything, double up the bus bars, repeat; same result. A 13 watt test light does fine but starter load makes it go open circuit.
    :wtf:
    It's out of the bike, on the concrete driveway and fancy dedicated lithium charger now will see what happens later today.
    Put the lead acid back in and vroom vroom....
    my only niggle was; getting the bike's hot lead screwed onto the last cell was a bit of a stretch. Hope I didn't mechanically stress something in that cell.
    Will see If I can rig up some more or less progressive test loads and experiment.
    It's not an adventure if the outcome was never in doubt. :sneaky:
  15. Mailman
    :D
    “I have not failed, I found 1001 ways to not make a light bulb.”
    - Thomas gggg Edison
  16. gggGary
    So kinda back burner messed 'round trying to get that battery back to life, no go. Finally emailed BatteryBackup and they are sending a replacement cell.
    meantime I ordered a 4 series 100Amp battery management System and will install that along with the new cell. This cat ain't dead yet.
    Paul Sutton, timbeck, Jim and 2 others like this.
  17. Jim
    You think that's pointing to a quality problem or just a fluke?
  18. gggGary
    Need to set the background; Batterybackup is a "surplus salvage" operation. They are buying batteries from big companies that use lithium batteries in their products, cells, batteries, power modules with; use by date expired, inventory that is no longer needed, high reliability product that gets periodic battery changes even if they have never been used. Design changes.... The usual gamut of surplus inventory.
    The cells I bought were priced at well less than half of "retail". Just like new product but with a failure rate you might expect to be a bit higher, there are going to be units units that don't meet spec or fail. That they are willing to replace, even though the cells I bought were "sold out" within hours of becoming available, to me sez they hold back some product to take care of "issues". I'm thinking that's an impressive way for a surplus business to operate/act. This is an experiment for me, a bit of risk acceptable.
  19. gggGary
    PS I picked these cells for their (appears to be) rugged architecture. For no special reason (Pete):rolleyes: I'm a bit concerned about the effect of vibration and a generally rugged environment on battery life.
    Paul Sutton likes this.
  20. Downeaster
    Downeaster Everything in XS Top Contributor
    Vibration? The hell you say...
    timbeck, gggGary and Mailman like this.
Share This Page
