1. Dismiss Notice
    Dismiss Notice
A little help
Discussion in 'The Garage' started by rsor, May 21, 2020.
  1. rsor
    rsor Wanna do this again!
    We're all hiding in the garage from a solid day of non stop rain. Been trying to research some information but no luck. I acquired this set of carburators, the choke lever and throttle stop screw were missing. I was able to solve the choke lever problem, but nothing for the throttle stop screw. Anything on Ebay is like $25 for one liitle screw sent to Canada.
    Does anyone know what size this screw is?
    A metric thread pitch guage, has a fit of .5, very fine thread.
    But what size is the bolt?
    Is there anything else I could use in place of that missing screw?
    I do have the spring for the screw.
    I thought about a machine screw double bolted on each side of the bracket, but there would be no easy adjustments made with that.
    Mailman likes this.
  2. xjwmx
    xjwmx It's just the unknown. Top Contributor
    7,285
    3,134
    313
    U.S.A.
    probably 6mm? I'd buy an overly long one and cut it with my dremel until the spring felt right on it. likely a hardware store item in the u.s. i'd replace that fender washer on the throttle shaft with a spring washer
  3. GLJ
    GLJ Never go faster than your guardian angle can fly. Top Contributor
    m5x15-.5
    Good luck
    Jim and Mailman like this.
  4. willis
    willis xsive compulsive disorder XS650.com Supporter Top Contributor
    I've got a spare if you need it. Postage should be pretty cheap, even to Canada. PM me if you would like it.
    Jim, GLJ and Mailman like this.
  5. Mailman
    Buddha approves!
    Jim likes this.
  6. rsor
    That's my trouble......no luck
    Jim and GLJ like this.
  7. willis
    Well I guess today is your lucky day then!
    Mailman, Jim and GLJ like this.
  8. rsor
    The wonders of this forum are truly amazing!
    THANKS!
    Superjet, Mailman, Jim and 1 other person like this.
  9. xjwmx
    7,285
    3,134
    313
    U.S.A.
    i wonder if it's stripped and that's why the screw's gone. might turn out to be 6mm after all...
  10. rsor
    Not stripped, takes a screw from another bike.
Share This Page
