cecil_t
I recently picked up a '77 XS650 with the factory dual-disk option, and I just replaced the brake lines with braided stainless ones. Cleaned out the fittings and reservoir while everything was apart (didn't seem too bad actually), re-assembled and everything fits nicely.
I added fluid to the master cylinder reservoir but it won't pump through the system regardless of what I do with the bleeders. I tried loosening the banjo bolt at the master cylinder and some fluid seeps through but I can get any to pump. I think the piston is stuck "in" and isn't returning.
What are my options, how do I get fluid back into this system? Once the fluid is moving I know how to bleed brakes, but I can't seem to get it primed.
