1. Dismiss Notice
    Dismiss Notice
adding magnets to pickup
Discussion in 'The Garage' started by wildboar58, Sep 12, 2020.
  1. wildboar58
    wildboar58 XS650 Enthusiast
    hey i have some 3/16 disk magnate s bout .150 thick can i put 2 on the pick up or i one enough?
  2. Jim
    If you're talking about the TCI pickup, it doesn't have a magnet. Putting one on there would probably block the rotor magnet.
  3. wildboar58
    i mean the one on the stator ,that picks up the slip rings on my 81 xs
    Jim likes this.
  4. Jim
    Rotors rotate, stators are stationary. ;)
    If you're talking about the part that rotates.... the rotor, it only takes 1 magnet.
    timbeck likes this.
  5. wildboar58
    it is stationary ,its black oval it sends signal to t c i .thats what i mean.
  6. Jim
    Back to my first answer then, it doesn't have a magnet. Putting one there would block the rotors magnet.
  7. 650Skull
    650Skull SSSSSSSSSlither Top Contributor
    Some people dig the old magnet out and replace............. Others have glued to the existing magnet........Have to make sure the distance between the Rotor magnet and the pic-up coils is correct for the magnet strength. If the magnet isn't strong enough, or the gap to wide, that causes a weak signal..........
    Pic to help distinguish the parts for future reference...........Might help next time when asking questions
    gggGary and GLJ like this.
  8. wildboar58
    sorry im late with pics . had problems with slow internet.
  9. wildboar58
    so you can dig them out.if you glue them it won't hurt anything .
  10. ippytattoo
    ippytattoo Just another grumpy old hack.
    The part you are pointing to is a pickup (sensor), there are no magnets inside that parts. There is a couple of coils that sense the magnet that is embedded in the rotor. If you try and dig out the "magnet" (actually just a steel core) from the pickup you will cause it to cease to function. If you add a magnet to the pickup it will block the signal from the magnet in the rotor and your ignition will cease to function. I think you don't fully understand what people are referring to when they talk about adding a magnet.
    If you insist on adding a magnet or removing a "magnet" from the part you are pointing to the only thing you will accomplish is disabling your ignition system and causing the bike not to start/run.
    But it is your bike so do as you wish and let us know how it goes
    Jim likes this.
  11. Jim
    Once again, what you're pointing at is the pickup coils. It contains 2 coils made of an iron core wrapped in copper wire. There are no magnets in that thing.
    Why don't you tell what kind of problem your having and maybe we can figure a way forward. Adding magnets where they don't belong won't fix anything.
    ippytattoo likes this.
  12. 650Skull
    I think you need to stop thinking and reread this thread until the information posted makes sense..........
    Magnets are in the rotor only...........
    Good luck..........
    Jim likes this.
  13. wildboar58
    ok thanks for straitening me out I guess I misunderstood on where magnets would go. the bike started up fine after rebuild ,the problem I'm having is it wouldn't start up later on.i tested the coil with multi meter it is in spec.i tested the rotor and its ok .the battery in good its glasmat and new ,when I turn key the neutral light comes on and horn works but no spark.
  14. Jim
    For starters, follow the ignition troubleshooting tree in the Yamaha manual.
    gggGary and Greyandridin like this.
  15. itschrisb
    itschrisb XS650 Enthusiast
    Sounds like your tci box has gone bad, but like Jim mentioned follow the trouble shooting guide.
    Jim likes this.
  16. wildboar58
    yea it looks like my tci box is bad. you cant buy them anymore can you? i,m looking at the gonzo suzuki gn250 i think i can wire it .
    itschrisb and Jim like this.
  17. itschrisb
    Highly recommend it!
    Jim likes this.
  18. wildboar58
    so it's pretty straight forward job?i can get on for about 43. bucks.
    itschrisb likes this.
Share This Page
