SpongeBobbed
650 Simpleton
I tried tackling the valve adjustment for the first time this morning and I've run into some issues and I was hoping to get some help.
I've watched the video by wildbill about 10 times and everything looks really straightforward. I have a Hugh's PMA system and was able to find tdc using Carbon's method, but now I'm having issues adjusting the valves.
When I set the intake valve at tdc there is no room at all between the tappet and valve and therefore my clearance is zero. Would the bike run if clearance was zero? The bike is running rough so I think it is a valve issue but I was surprised to see it at zero.
When I go to adjust the valves using the tappet I can't seem to get the rocker to do what I want. When I loosen the nut on the tappet and thread the bolt in, it just pushes the tappet further down on the valve and won't give me any clearance. Doing this takes away any play in the rocker though.
When I loosen the nut and thread the bolt out, pressure comes off the rocker and I am able to get some clearance between the bottom of the tappet and the valve, but then the rocker has a lot of play in it and I can move it up and down very easily. I assume this will cause a lot of rattle when the engine is operating.
Is this completely normal? Or is something going on here? I've included two picture below for reference. One with the valve and tappet touching and there's no rocker play and another where there is clearance but the rocker has a lot of play.
Any help would be greatly appreciated!
