Some of you machinist guys should start making these. Aluminum knob pressed on a splined steel shaft ..... I'd give $20 for one of those.
A very wise friend of mine once said "...nothing was ever made that couldn't be modified..."
If you can't find it anywhere, make it yourself. Besides the satisfaction, the part is instantly "custom".
I like thisPeanut, my SH has a different setup but this is how I repaired it:
Original right side plastic clip (My left side one was broken off):
I matched the profile in brass combined with one of those plastic topped screw thingys:
View attachment 113408 View attachment 113409
The finished item with a rubber washer added:
You may be able to do something along these lines.
Thanks for the name "fluted knob" - now I know what to search for in future. They are handy things and I usually end up poaching them off my mitre box or saw bench. I currently need some for a telescope.
On the SH the covers are less likely to fall off because the two clips at the top are at different angles. This means there is a set order in how they must come loose before falling off. But I guess if its possible then it may happen!
Oddly, Lucille’s covers were still the 1976 factory red colour when I got her but they showed no evidence of ever having had decals on them.
Pete
