I went PMA when MrRiggs educated our world as to all of the 3 phase PM stuff that is sitting in the bone yards. I use the stator mount that he cast - I don't know if he still sells them.
I think that it is cool to re-cycle.
I first ran PAMCO and the coil that Pete recommended, with a SPARX capacitor and no battery - The stock motor would usually start on first kick with that set-up.
The proper coil is the key. You want one hot enough to fire with the low output of the kick, but not so hot as to fry itself or the PAMCO the first time a plug cap comes loose. Follow Pete's advice on this one. NO GREEN MONSTERS
I recently changed motors (still no starter motor) and with its 10.5 pistons I decided to put the battery back in - just in case - 'cause that compression is hard on your boots.
The only locks I have on my bike are on the gas-tank, and I will get rid of those when I do my next round of mods.
The only switches you REALLY need are the horn button, rear brake switch and the Hi/Lo dip, but that is a bit more minimal than I would advise. I suggest a toggle switch for the main circuit (ignition. brake light switch, horn, on/off light switch) toggle for the lights and rocker for the dp
I run a 20 amp fuse for the main crcuit and a 5 amp to the igniton.
You can take the 20a fuse out when you park it (as a securty measure).
