Next came the carbs…
I was pleasantly surprised to see that the bike came with 78/79 linked carbs. This was good because I have the same set on my bobber, so this will allow me to use some of the jets that I had left over from that build.
Of course, no carb rebuild is complete without some butterfly screw removal and bent shaft drama.
To remove the screw, I ended up TIG welding a long M3 SHCS to the Philips screw. The heat from the weld helped break the rust bond, but not before I had bent the shafts while trying in vain to remove the screws using a traditional screw driver. I straightened the shaft by gently bending the shaft in the opposite direction of the bend and test fitting to the carb body until the shaft turned freely.
Cleaning wise the carbs turned out ok after 4-5 hours of ultrasonic cleaning using a 50/50 mix of Simple Green Pro HD and water.
I set up the carbs with the following; 140 MJ, 30 PJ, Needle jet #2 position from the top. This is a guess since I intend to run UNI-Pod filters and a quiet set of mufflers.
The carbs did not come with any holders, so I ended up having to buy the 48-7479 holders from Mikes/XS650 direct. Heard lots of comments on this site regarding the rubber materials they use, so let’s hope these hold up. There didn’t seem to be many alternatives for the holders. The fitment was OK-ish although I had to shorten the barb on the RH side to clear the valve cover nut. I also had to clearance the band clamp lip to clear the SHCS I was using to mount the holders with. Even with the clamps fully tightened, I felt that there was still some carb play in comparison to the OEM holders on my bobber. Time will tell I guess…
