Boy, JRay77 - you sure know how to throw a party!
has to be typed backward in Australia
No GG we are not backwards here just upside down. 8)Maybe the code has to be typed backward in Australia? They're showing up for me even after a rocky border crossing.
I think I would go with new coils.
Hi GLJ... I think that makes sense... I also had a look at this thread and I'm warming up to the idea of a dual output coil...
http://www.xs650.com/threads/dual-coil-with-points.16803/
What will you be running on your XS2?
So over the holidays I sorted out the exhaust, and prepped the bike for test firing. Since the wiring was a mess I decided to bypass the wiring and run it directly off a marine battery.
It started with little effort. The dynamic timing needed very little correction from its static settings. I Confirmed the point gap with a dwell meter, and it too was also very close. The cam chain was too tight and needed to be relaxed a bit to get the adjustment pin to dither by about 1mm or so.
Mix screws are at about 3 1/2 turns out. The jetting on the BS38's are; 140 MJ, 30 PJ, Needle jet #2 position from the top. I think I might need to go up one more size up on the pilot jet as it seems that mix screws are quite a bit out compared to the stock setting of 2 1/4 turns.
Here is a short video after running and warming it up for a few minutes.
The Triumph mufflers give it a muted tone but I think I like it. I've got a bobber that wakes up the neighborhood at will, so quiet is kind of refreshing.
Towards the end of the video it appears that carbs shake quite a bit with MIkes Xs carb boots... as noted by others that doesn't look like that will work long term. Not sure that would go away even with the metal shroud attached to the boots.
Anyhow, I needed to know that the engine ran before I continue to invest time and heartache wakening up the butchered wiring, and the the rest of the bike.
