Barn Yard find - 73 TX650
Well this took an interesting turn...
The two cars may share some of the same chassis components but the chassis itself is different. I had a 562 and the chassis was normal round tubing, not square tube like yours.
So, a quick update…
My package from Hieden tuning finally arrived (2+ months in transit) with the straight carb boots in place of the angled versions, the side covers easily fit.
The Heiden boots were a very precise replica of the OEM versions, and allowed me to use the OEM steel boot cover, and clamps… if they’ve chosen the correct material then I should be good to go… very happy with the end result.
ACtC-3fy6_H96aEg2_AyJf06Uzm1q0SiyrKyn2eaddOLHx42j2LXvbPzSqGTLekCXdUeKvD2Y04Q-5oR0CMvcUadAyicKU8QpZrQyIaozcG8vG8KMsyJHTFVoGdiyhUqe7S4hQ7YzWyK4_H-RwFSXZ0JaFyWYg=w1351-h1013-no
Also did a bit of work on the sidecar mounting… First off I converted the front engine mount to accept two M16 anchor bolts to attach a sub-frame on to the bike…
ACtC-3c3ZWpQOaqQtDPOHFjS6Y-951_ocSIyh0RQLvTNTfUH1M9tY54Ree1Q1gepG6u33X7eY7JopT62R59eMSB8ImajOBGftHW2cIo86gObJtOKy8meFESrFVVveRDSLYF2gPLJeKG4tgk4QI-OKAdRO_KRRw=w1351-h1013-no
Next I doodled, with the help of a 3D printer, to conceptualize as to what a sub frame might look like… I wanted something that would be stealthy and easy to remove so that the bike could be enjoyed without the sidecar and sub-frame. For this reason, I also favored something that would allow me to keep the center stand…
I haven’t finalized the horizontal arms and their connections to the sidecar, but this is where I’ve got it to now.
ACtC-3eOZx0NxbZigk8DEVEtXjo7pcX_Z8NIDyei_qGblqTCySyBiV-2C03PJ06_MxELwj1byZy998-PTv3dyHLpA92sqRz9dkbMCeBxFAozGLwwRES-rx4eqVhiZ4vtZfATFpoSfpqOeMXuopEhRC34rmgcGg=w1351-h1013-no
ACtC-3fehL3cLJQ0Kcu2Be_L8baUsI7W7TyViQb03hYLWIjCwLStlh2qONHjVVhYbc1HL-gCD5GDNb8lXZlV3thJ0erezi-OKsEOkHANCYAx8HAQTjLBxr7q2t5nKsFajeJqQd-5VWan1CT-TGRnhKC07ydSPA=w1351-h1013-no
ACtC-3dWx-2PDn-pD5t69eJiysCZeBLNpy4Fp1rwvQHAzYpufVJkYOSPaMIRq77DJTzsNBXkklWpAFaXeuRJeogr_du5-U2wWrcp7ClDyHTlaAmQieIu97LzFqLdzjpi41WGsmJKMdSiFo2ZoDOBiXEQM2t6cA=w1351-h1013-no
ACtC-3fFkak1_7D17d8gfajdSip0XmEz_Hm_RxDDcoMLVacfwpVmMiqJlNvQQz4XmuRvC3FaEWqWvfs7-_cIO4UNDQ02idaiDjJ4cFCKxzA0CwGiCIzqaHj1asWrmr3qDheoLouceSBWOKpkBxsk-_do9MCWew=w1351-h1013-no
Unfortunately, things are going to come to a bit of slowdown, as life intervenes with its twists and turns… might be a while before I get back on this…
