1. Dismiss Notice
    Dismiss Notice
Batteryless xs650 capacitor fell off during ride
Discussion in 'The Garage' started by Anthony1993, Jul 20, 2019.
  1. Anthony1993
    Anthony1993 XS650 Enthusiast
    34
    14
    8
    Arizona
    jim.. awesome video!
    just did each test he did
    not sure what i did wrong the first time, but this is what i got
    black probe to red wire red probe to yellows
    1/.480
    2/.487
    3/.503
    red probe to red wire black probe to yellows
    1/OL
    2/OL
    3/OL
    black probe to black wire red probe to yellows
    1/OL
    2/OL
    3/OL
    red probe to black wire black probe to yellows
    1/OL
    2/OL
    3/OL
    black probe to red wire red probe to yellows ( on 2M ohms setting)
    1/1.079
    2/1.677
    3/1.180
    red probe to black wire black probe to yellows ( on 2M ohms setting )
    1/OL
    2/OL
    3/OL
    as far as i can tell all the numbers are suppose to be in range of each other, but i dont have enough knowledge to declare if its bad or good. what do you guys think?
  2. Anthony1993
    34
    14
    8
    Arizona
    when i hook the battery up to the bike, should i give it a kick and see what happens?
    and what will i be looking for?
    would it just be a means of supplying power to the bike so i can do further test?
  3. Anthony1993
    34
    14
    8
    Arizona
    i was just looking over my list and i think i skipped a test. im going to double check all my test and report back with more numbers.
  4. 650Skull
    650Skull Dinosaur Lives Top Contributor
    Having no on/off switch or fuses is a problem, when hooking up a battery, the whole loom will be alive from the get go...........i just made the suggestion about the battery so there was no confusion about how to, in case the car was running to keep the battery charged.
    I don't think running power through the loom is necessary to check anything............This can be done when the bike is started and then power voltage reading can be checked.
    Sorry i didn't mean to side track.........just a precaution
  5. Anthony1993
    34
    14
    8
    Arizona
    ok triple checked all numbers and contacts to make sure its reading and this is what im getting from the rectifier
    black probe to red wire red probe to yellows ( on diode/ continuity)
    1/.478
    2/.485
    3/.502
    red probe to red wire black probe to yellows ( on diode/ continuity)
    1/OL
    2/OL
    3/OL
    black probe to black wire red probe to yellows ( on diode/ continuity)
    1/OL
    2/OL
    3/OL
    red probe to black wire black probe to yellows ( on diode/ continuity)
    1/OL
    2/OL
    3/OL
    black probe to red wire red probe to yellows ( on 2M ohm setting)
    1/ 1.683
    2/ 1.178
    3/ 1.044
    red probe to black wire black probe to yellows ( on 2M ohm setting)
    1/OL
    2/OL
    3/OL
    black probe to black wire red probe to yellows ( on 2M ohm setting)
    1/OL
    2/OL
    3/OL
    red probe to red wire black probe to yellows ( on 2M ohm setting )
    1/OL
    2/OL
    3/OL
    Jim likes this.
  6. Jim
    Yeah... that's no good. You're missing half your bridge.
    ...And just for your info, you said... "black probe to red wire red probe to yellows ( on diode/ continuity)." On the diode function, you're not checking continuity, you're looking at voltage drop across the diode. The number .502 for example means you're losing a half a volt... it has nothing to do with resistance/continuity.
    TwoManyXS1Bs likes this.
  7. Anthony1993
    34
    14
    8
    Arizona
    thanks for the info that makes sense. the only reason i put that is because on my multimeter the instructions say to check the continuity with a specific setting and then the intructions for checking diode says to put it on that very same setting.
    Jim likes this.
  8. Jim
    Yeah, I've seen that before too. I've also seen meters where the diode function was included inside the resistance scales. Only thing I can figure is the Chinese are copying stuff without understanding exactly what they're copying. :doh: If you look at your readout, when you switch to "diode", a V should pop up... indicating you're reading is in volts. I think I pointed that out in the rectifier test video.
  9. Anthony1993
    34
    14
    8
    Arizona
    multimeter.jpg this is my multimeter the diode/ continuity funtions is the arrow with the plus sigh a couple clicks to the right. i dont get a v on the screen when i switch to that function. or any of the functions for that matter ?
    gggGary and Jim like this.
  10. TwoManyXS1Bs
    Yeah, it's a diagnostic tool, not a training tool. They kinda expect the user to understand how and what he's measuring. Not a problem, listen to Jim and 650skull...
  11. Jim
    Maybe not showing the function is a cost cutting measure.... :rolleyes:
    gggGary and TwoManyXS1Bs like this.
  12. TwoManyXS1Bs
    Justa something to consider when running high-capacity capacitors, like the Sparx.
    Fully charged to +12v, a 15,000mfd Sparx capacitor will light one of your tiny 3w instrument bulbs for just under 1 second.
    Assemble 8 AAA batteries into a little 12v gang, and they will illuminate that tiny 3w instrument bulb for anywhere from 3 to 5 hours.
    That little AAA battery pack has 10,000 to 18,000 times the storage capacity of the Sparx.
    Multiply that by 15 to compare to a regular motorcycle battery...
    Rasputin, Jim and gggGary like this.
  13. gggGary
    My 2HP VFD runs it's cooling fan for about 10 seconds after I unplug it.
    Still makes me do a double take...
    Jim likes this.
  14. Jim
    Ever have a cap. from an old audio power amp tag ya? :yikes:
    gggGary likes this.
  15. gggGary
    Was warned at a very young age about sticking my fingers in the back of TV's.....
    GLJ and Jim like this.
  16. TwoManyXS1Bs
    Oh, yeah, flyback caps hold thousands of volts.
    Yeowch!
  17. TwoManyXS1Bs
    Just outloud thinkin' here.
    Typical lead/acid batteries have an intrinsic internal resistance of a fraction to almost 3 ohms. Signal filters and power dampers usually use a capacitor and resistor in series, known as an RC (Resistor Cap) filter.
    I don't know what, if any, internal resistance exists in the Sparx capacitor. But, suppose you were to add an Ohmite power resistor, of say 1 or 2 ohms, in series with the Sparx. A capacitor by itself acts like a voltage spring. The resistor would dampen some of that springyness. Maybe the budget regulators would appreciate that...
    Edit: I don't have a dog in this hunt. Just throwin' chum in the water...
  18. Anthony1993
    34
    14
    8
    Arizona
    thanks for the tips guys! so do we have a consenses that my regulator is fried?
    Jim likes this.
  19. Jim
    Well, the rectifier certainly is... assuming you tested it correctly, you've lost half the diodes. I'm late to this party... don't know if you have a combined reg/rec?
  20. TwoManyXS1Bs
    Your 4th test certainly shows a failure:
    1/OL
    2/OL
    3/OL
    It appears that the red wire is indeed connected to the internals.
    The black wire may have a break or disconnect somewhere. It's rather untypical to lose all 3 diodes at once. Just something to check...
Share This Page
