I'm about to do this on a Honda CB350 engine I'm building up. I bought a Tsubaki chain, but at the moment I really don't want to split the cases to install it. So I bought a master link with the chain.
My main question is how in the heck is this a stronger solution to the clip style master link? It just looks like some sort of copper alloy. I understand that there's not much force at the side plates to pull it apart though. With so much room for error depending upon who is installing it, you'd think a clip style would be just as safe when confined to the internals of an engine because there should be nothing for it to ever catch on and come apart.
I don't think there was a clip style master link available from Tsubaki for the chain I got, or I would have opted for it.
I've been fretting over how to do this ever since. The rivet tools are expensive if you're not buying the 50 dollar Chinese ones from ebay. However, it seems like not really that much pressure is required to flare a rivet style link because the metal is soft? I was thinking of using a C clamp with a modified 'anvil' made out of a ball bearing (since it'd be hardened metal.)
Am I overthinking this? I've read everything from Xing it with a chisel like above to smacking it with a ball peen hammer holding a heavy maul on the other side to deaden the blows?
Then you have people saying you need 300 dollars worth of tools to do this right. A chain press, and some sort of Ducati tech certified tool to press the rivets out to a specific thousandth of an inch if you value your life at all.
So I'm trying to dig through the dirt and figure out what will suit my needs.
So far, this is my three dollar clamp idea:
Does it look stupid?
