fyrman41
Typical gear head
So I though I finally had my bike tuned properly. It was pulling hard and running great. No it idles as if the choke was partly on. Just to keep it running standing by itself the idle screw needs to be almost all the out. The midrange on up run smooth but dont seem to pull quite as hard as before it acted up. I tried going down to #30 pilots with no change. Pull the vacuum tubes off the barbs and she will take off to 1500 rpm. The mixture screws have very little to no effect. Ive checked the floats several times making sure they are at 24mm and not bent or pushig down on the needle. Floats are good and have no cracks, needles dont leak. I got fuel the night before it started. Pit Stop 91 octane ethanol free gas. Could it be Bad gas? I cleaned the carbs up making sure every single passage way was clear. Even the air jets. IUed carb cleaner. Even tried new pulgs, and it blackened them in a hurry. Maybe weather change? High 70s to high 80s with lots of humidity. Im very stumped and frustated. Both carbs or do8ng the same thing but the left a bit more than the right
Posted via Mobile
Posted via Mobile
