Jaymichael
Hey guys, I am hesitant to make this post, I know there are quite a few threads related to this issue. I was going to give it another go on my own tomorrow but I'm feeling pretty deflated at the moment. Turning wrenches on cars for 15 years I must have bled a couple hundred master cylinders but this things got me licked.
My parts, Hughs Handbuilt slimline master cylinder. Stock rebuilt single piston caliper. 1 piece stainless line from master to caliper.
Attempts made. Caliper and line filled with fluid prior to install. After install used vacuum type bleeder on system, ran about 6 to 8 master cylinder fills though the system, zero lever feel achieved. Performed typical pump, hold, open bleeder screw, tighten bleeder screw rinse repeat about 30 to 40 times. Noticed very slight resistance in lever just before touches bar. performed gravity bleed to system various times, bleed master by cracking line on exit of master cylinder at banjo bolt many times. Went back over system using all these methods over and over, threw wrenches various time
I feel like I tried every variation I can think of, my master is perfectly level, Im just not getting anywhere. I would say I feel brake resistance start at about 70% lever pull and it will not touch the bar now. I gently rode around my parking lot at school and the front brake does function, but the travel is way too far for my liking and there is no way I could lock the front brake up even if I tried. I left the master open for the night, hoping any air trapped may migrate up top.
So, any thoughts guys? Something I'm missing here? Any help appreciated.
