So on the way to getting ready to crank this motor I had a throttle cable issue. The sheath was about an inch too long...or the cable was an inch too short... My first thought was to pull the ferrule off the end but it was crimped so tightly on the plastic cover that there was no way that was coming off without destroying it.
I ended up cutting the cover and all about an inch back and slid if off the sheath
Then I cut the exposed sheath off at the end of the plastic.
Now I cut the plastic cover back again about 1" and slid the ferrule end back over the sheath...fits perfectly now...
I figured I should have something on the exhaust side of this motor before I fire it so I cut the headers off at the mounting tab so they would actually fit
I even put my new Father's Day gifts on finally...Not sure I like the placement but it'll work for now.
I had oiled up the UNI filters with a 50/50 oil-gas mix as I had read on the forum here from someone, filled it with oil after putting on the right side cover, and then a lot of nothing happened...
I made my order yesterday for the Pamco, e-advance, bushings, and plug caps so in preparation I thought I'd get this thing ready to come off of the table when the ignition gets settled at the end of the week.
First it was the oil tank, 3/4 inch hole for the key switch I picked up from TSC... and then on to a larger hole for wiring to enter/exit the tank.
I used my step drill to get a 1 3/8" hole that over lapped onto the end cap.
I cut through to the end of the pipe so the wires can get taken in or out without having to be unhooked
Then installed my rubber grommet
On to the chain. I have a parts unlimited 530 heavy duty 120 link chain. I put the chain on the top half of the rear sprocket, ran it around the front sprocket, and pulled it as tight as I could to the bottom of the rear sprocket. It worked out that with the wheel all the way forward I needed to cut 8 links out. I used my harbor freight chain breaker and it worked perfectly...really glad I didn't spend big money on some other one.
I installed the master link and backed the wheel out until I had about 1" of total deflection and it ended up being about right about in the middle of the axle slot so I should have plenty of adjustment.
Looks good
Then I cut, bent and re-welded my kick stand. I hope it's short enough. I only cut about 1/2" to 5/8" out of it, but I bent it pretty well.
This is where it sits now.
Next I need to take the carbs off again and work on the left one. It was pouring gas out once I turned on the petcock. I figure needle valve or float issue there. Still waiting on my ss brake line to come in. I suppose I can get the clutch cable and left side cover installed too. The list is definitely getting shorter. One of these days I'm going to have to get to work on the rear fender and either get rid of or clean up the front one.
