Boyer Bransden timing on 76 ?
I’ve had some problems dialing in the carbs as playing with the fuel mix screws doesn’t seem to change my rpm, even at extremely low idle of 3-5 hundred. So I thought I would re-look at the timing. So I want to make sure I have this right. I've been reading this thread but want to make sure I am translating everything properly.
http://650rider.com/index.php?name=Forums&file=viewtopic&t=5603
Does my text picture look accurate for the Boyer?
|__________|F|____T_|
|____________|
3500..............1200 rpm
rpm
Boyer says
"Strobe on the old full advance mark by reving up and watching it line up"
Is my attached thumbnail above correct?
Update from Boyer:
"The electronic ignition*will be fully* advanced by 4000rpm, use this rpm or higher."
