BTW, how did you come to spot that chain trouble before it did a complete comealoose? Good job!
Shear luck is all I can say. I was all laid back, legs stretched over the hi-way pegs, leaning against my pillows, cruise control set on 75, one arm thrown back over the packs and the other hand (the left) kinda keeping control on the bars really enjoying the sunshine after the previous days 100 mile rain. I was contemplating engaging the auto pilot and taking a snooze as I still had 3 - 4 hours riding to do. When I get in those grooves ANY sound that is different is easily noticed. And the new steady tack tack tack got my attention but not as quick as the accompanying (remember it was my left hand on the bars with a couple of fingers on the clutch lever) knock I was feeling through the lever. Very slight but you could still feel it. Hands are just amazing things for feeling differences. It probably didn't take 200 hundreds for me to hear/feel the difference get shut down and on the shoulder. I don't like hanging out on shoulders not even nice wide ones so I limped on up to a side road to get off the hi-way another 200(?) yards. That is where I discovered the offending piece.
Tonight I found some round 2 it and started checking things.
The first mystery was apparent right off the get go. It seems to be hard plastic, hollow. and wrapped around the clutch cable.
Set that aside for further thunking later.
Next I rotated the chain, as the broken link gets pulled onto the sprocket the sideways bending lets it start on the top of the tooth.
But as it travels it settles into the gap. But doesn't fully seat.
Rolling it on around I see 1 broken roller and 3 that are MIA.
Well the chain is trashed, that goes without saying. But what is the other damage.
I don't see any scratches on the push rod.
The case is another matter unfortunately.
It will take more cleaning to determine how bad it is. Hopefully a good cleaning and some JB will be the repair.
So where is the mystery mentioned in the title you ask? All the damage is apparent and obvious no mystery there. And the plastic hollow tube? I'm thinking it is from the skid plate that protects the shift shaft as it also shows a little wear and tear.
The mystery is I cannot find the clip for the master link.
Two days before the ride I mounted and balanced a new tire so the chain was broken then.
The clip was reinstalled correctly at that time. But I've been round this chain 3 times and can't find the clip.
I've grabbed each and every outer plate with needle nose pliers and tugged, wiggled or pried.
I can't find one that seems loose. None of the pins are showing the clip grooves.
Later today I will roll each pin on the rear sprocket and give each a whack with a hammer and punch.
I would like to locate the master and see where it is in relation to the break.
