Item #25, the book shows four of them. Can’t be. The stud is 14mm inside the shock and 10mm on the outside. There aren’t many threads for the nut with all washers on there. I ordered what’s in the picture. I’m interested to find out what I get.
Yep. Just looked at the SG Marty. The shock's are sandwiched 'tween a pair of washers..... 4 total.2 on each shock?
That’s what the parts book says. Two flat washers and a lock washer on each shock.2 on each shock?
I had meat in the bag. Nothing else. It weighed probably 10-12 lbs. I’m not much over 200 dressed to ride.I am curious @jetmechmarty as to how much weight you have in that tail bag. They can't hold all that much unless weight you are carrying gold or uranium...
I’m thinking this has to be simple. The bike is stock. I’ll just get thin washers in 14 mm.You could also consider leaving out the inner washer or corbeling the inner washer hole so it sits with the outside of the washer flush to the bung face.
I'm not surprised as what's listed in the parts book doesn't fit!Neither seem to have any washer on the inside.
