Sold / Found / Inactive - BS34 Carbs, Uni Filters, Jets and more
Bushyeyed1
Cafe Racer
Wahiawa, HI
A set of Uni Filters, BS34 Carbs, many extra jets, needles, and other hardware. I have all this left over after selling my XS650. One of the carbs is completely functional the other side needs some love. No holes in the slide diaphragms. The filters were only used for mock up and never oiled. Asking $60 plus $15.05 flat rate shipping in the USA.
If anyone wants anything separate I will part this stuff out too. Just let me know what you need and I’ll work something out with you. If you only want the Functional Left Side Carb $25 plus shipping. If you only want the Uni filters $20 plus shipping. What’s wrong with the right side throttle body you may ask. The idle air fuel screw is stuck and needs to be drilled out, the needle jet needs to be replaced, the butterfly screws have been drill out and unfortunately the shaft needs to be either retapped or replaced, and a small dent in the float. If you broke off your post trying to remove your float though may be something you need.
