Oh... and there's a spring inside that barb plate. Careful... if it launches itself high enough, the jet stream will send it my way.
The back (barb plate) is all you need to turn around. Leave everything else be.Hoping I can just turn the back around but sounds like I'll need to move some other things as well.
Can you help me tell the difference between a B34 and a B38 carburetor? I have a huge fuel problem and I was told to tell a member here which I have. I don't know which.Hi All,
I'm a newbee trying to rebuild carbs on my 1980 XS650G. I know there's a LOT of previous discussion about this but after reading a bunch of it I'm just confused. Some say confused is just another word for stupid & maybe I am bc I don't know how to proceed. The bike ran when I parked it years ago, but poorly.
One of my floats makes a funny noise when I shake it and when I place it in water it floats with that side lower than the other so I'm pretty sure there's gas inside. Maybe this was the problem way back in 2004. I tried to find a hole or evidence of a leak but can't see anything. I placed it in hot water but no bubbles appeared. I don't know how to repair a leak I can't find. Some posters say I shouldn't try bc heating to solder is likely to create additional leaks or at least cause them to become more open.
I'd hoped that it wouldn't be a major project to get this bike running as I already have several projects taking up my garage floor space. My inclination is to just buy a new float but I've tried and tried to find a source for a replacement float. Hard to believe that Mikuni wouldn't provide the part since there seem to still be a lot of these bikes on the road. Mike's shows one but reading the detail my bike is not among those listed. Saw a post where someone said they ordered this and it seems to be for bs38, not bs34. I don't want to order a part that won't fit.
It seems that some folks are using plastic floats to replace the brass but I don't know which ones to get. Is there one that fits or would it need to be modified? Also not sure if there's a float height spec for the plastic or if I'd have to hook up a gas line to the bottom of the float bowl in order to visually check float height.
Any help would be appreciated.
I hope you are getting more support than I am. I would help if I knew what to say but I'm inexperienced and would probably just cause more problems for you. So was your carburator leaking to?Hi All,
Nice...
Look here. TourMax branded... made in Japan. These'll be the ARS intakes.
I've installed 'em both ways... forcing the carbs on... and putting the the carb in the boot first then installing the boot/carb on the head. Both are doable.... neither way is easy.
