I went back up this thread,
You might want to do a second round;
set timing with a light (both sides), look at idle, advanced and smooth action between.
cam chain tension valve clearance,
Check for strong spark, both sides, etc. condenser issue comes to mind.
Compression test recently? results?
This is out there but it HAS happened more than once, the stock headers are double wall, a few guys have found a collapsed inner wall, severely restricting the exhaust on that side.
lets see some pics of the bike including the air filters.Before I initially tuned the carbs (only like 40 miles ago) I adjusted everything else (timing, cam chain, etc.) first like you’re supposed to. Now just so you know, this bike is running open headers and pod filters.
