It's in the BS38 throttle shaft seals (who's done 'em who needs to) thread. Page 2, 5 posts down from gggary.
"Sketch the plate position before you start so you know where the stamped mark goes. I have doubled up the 4 sided "o-rings" from mcmaster carr seems to work well. +3 when backing out a screw either use the impact hammer or lots of down pressure then start adding twist till you feel that sweet little clink of the threads releasing. It's all about stability, the carb has to be blocked so it can't move and backing up the shaft is a real plus. If anything can wobble you will strip the slot. A low table lets you get steady weight/pressure over the end of the screwdriver while applying twist. An assistant to hold the carbs is not a bad idea. Once you have the plates back in and the screws lightly seated. Lightly snap the throttle closed a time or two, tighten and recheck, there should be very a small uniform amount of light around the plate looking through the throat. If you are a known screw head stripper, best to leave this project to others...... because you can go from bad to worse."
