xs650dude63
How far is the pin supposed to petrude when turning over the engine, mine pops out about 2MM past the surrounding metal, should it be flush with surrounding metal, then go back in? Thanks!
Here is another simple method, that I use. I take the bike out for a short ride to get the engine hot. Once back in the garage, I remove the camchain tensioner nut, and re-start the engine. I use a small 10 mm wrench, to turn the adjuster nut in until there is no motion at all. Then I back out the adjuster nut 3 flats. That's it, shut off engine and replace tensioner nut once the engine is cool.
Maybe just gum cooked on the threads. Mine would only turn by hand cold, not hot, until I had it off and apart once and hosed it with brake cleaner.On some of these, the adjuster doesn't turn easily by hand,
