Thanks, 2M. So it really is the whip as well as the slap - I had been wondering because I've yet to see a drive chain on a bike with a guide on the top run, and the same principle must surely apply. But as you can probably tell, I'm no engineer!
I absolutely agree Pete.... and thanks for the comment. As 5twins has previously stated, he's never seen the rubber come off the SR500 guide. And the Hiloks give us about a thousand lbs. of sheer force... yeah, way overkill there. Those facts and the ones you stated should make for a guide that will last practically forever.I feel (and I think that Jim may agree) that the central rail SR500 design is superior to the older XS650 “channel” geometry because the rail contacts only the nice smooth surfaces of the chain rollers rather than the potentially sharp edges of the chain links themselves.
The raised center is good, but I think there are benefits to having the sides forming a channel like in the original. Because -- if the chain is way loose or the guide crooked, or etc., the chain my simply slip off the guide = nightmare. Maybe combine the two ideas. I'm not following this thread at all but someday will probably benefit from y'all's work here.... I feel (and I think that Jim may agree) that the central rail SR500 design is superior to the older XS650 “channel” geometry because the rail contacts only the nice smooth surfaces of the chain rollers rather than the potentially sharp edges of the chain links themselves. ...
Pete
I could probably make the argument that if one lets the chain get that loose, this hobby's really not for you....The raised center is good, but I think there are benefits to having the sides forming a channel like in the original. Because -- if the chain is way loose or the guide crooked, or etc., the chain my simply slip off the guide = nightmare. Maybe combine the two ideas. I'm not following this thread at all but someday will probably benefit from y'all's work here.
If there isn't room for it to come off that's good then.I could probably make the argument that if one lets the chain get that loose, this hobby's really not for you....
Truth is there isn't room for it to slip off.
The fact that there ain't room for it to fall off kinda makes it idiot proof.... no?when you design something you must absolutely make it idiot proof.
I ain't in business... problem solved.In business it keeps the phone from ringing
I ain't an engineer....and it's just good conscientious engineering practice.
We'll leave aside for a second that I don't have customers to blame.... There was nothing there for me to prevent. Again, there ain't room for the chain to fall off.Blaming the customer for something you could have prevented doesn't work.
It does. That's what I meant by "that's good". No problem. But if it could come off, if the user was being an idiot, and it comes off, everyone will rightly say why did he make it so it could come off... If a plane control cable comes loose if the pilot is being an idiot, what you must do is make it so it won't come loose even if he is being an idiot. Not harping, just being theoreticalThe fact that there ain't room for it to fall off kinda makes it idiot proof.... no?
Someone once said that you can't make something idiot proof.... 'cause idiots are so smart. There's a grain of truth there.But the thought that if you let it get that loose you shouldn't have it is wrong -- when you design something you must absolutely make it idiot proof.
