Peejay
Hi guys,
I suspect I know the answer but has anyone managed to change the cam chain tensioner & guide on a 1981 model without removing the engine from the frame.
Is is possible to remove the head, jack up the barrels and access the 4 retaining bolts on the tensioner bracket?
Can the barrels be removed by taking out the studs and lifting off the pistons?
I know it sounds unlikely but it would be easier if the crankcases could stay in the frame for me.
