avenue
push.
I installed the cam chain tensioner last night on my fresh rebuild and never saw any movement in the plunger rod so I removed it for further inspection. I noticed two washers, one small and one thicker with a shoulder, between the spring and threaded adjuster. These two washers are preventing the plunger from getting past flush with the outside of the adjuster. In other words, the plunger bottoms out just before being flush, preventing any accurate adjustment/reading. Removing the thicker washer (almost a spacer) allows the rod to freely pass through the adjuster a few mm before bottoming out on the small flat washer.
Any thoughts? Did the PO add an extra spacer for some reason? I don't see it in any schematics but the adjuster was stored in a ziplock bag over the past few years (by PO) with almost every nut and bolt painstakingly chronicled for reassembly. So far, most all of it has been accurate so the thick washer is throwing me for a loop.
thanks,
avenue.
thanks,
avenue.
