Hey guys, if the guide stoppers are still not available any time in the near future, I'm planning on reversing the shape of the aluminum cast part of it, then machining a replacement (Delrin possibly, I'll look into what plastics will do best with oil and heat as well as wear resistance) part. Then, as of now I"m thinking like 4 8-32 socket head cap screws spaced evenly over the length of the thing, I'll drill and tap the aluminum part of it. Then on the plastic replacement part, drill thru, and c-bore as deep as possible (to allow for wear with out the chain touching the heads of the screws) The only thing I don't like about it is if someone where to let it wear too far you can see the obvious problem. I'd much rather just buy one, but obviously they are not available and the plastic has completely fallen off of mine, I see this as a decent fix I can do myself. On the plus side, replacement plastic parts would be cheap, and easily replaced....Any one else have any interest in such an idea? I'd be open to this to others if any one is interested....
I'm open to ideas as well... I'm not sure when I'll get to it, but I'm planning on a ride first week of june, so hopefully before then....
