There is a loud whistling/chirping noise coming from the right side of the motor. I've checked the choke plate screws, which were loose, but tightening them did not stop the noise.
I'll second the exhaust seals. The best tool for finding at least the general location of noises is a common automotive stethoscope. Leave the probe on for mechanical sounds, or remove it and listen through the tube for airy sounds. Good for locating vacuum and exhaust leaks, window leaks in cars, isolating which side or area of an engine is knocking, etc.
I had a 'chirping' noise from the r/h top of mine a few years ago.I thought it was something to do with the valves/cam
..I was absolutely convinced it was mechanical but after a lot of investigating it turned out to be a leak at the vacumn pipe pickup on the inlet rubber..!
