1. Dismiss Notice
    Dismiss Notice
Can I turn my Engine upside down?
Discussion in 'The Garage' started by Grimmith, Sep 18, 2019.
  1. Grimmith
    Grimmith Samurai
    295
    288
    63
    Iowa
    I feel like it's a silly question but when I searched anything involving this question I couldn't find any in past posts, I would drain the oil out first, But I need to make an oil catch for my race bike and want to at least have it bolt to 2 or 3 bolts if possible.
  2. Downeaster
    Downeaster Everything in XS Top Contributor
    Drain the gas out of the carbs too, but yeah, no problem.
    Paul Sutton and Grimmith like this.
  3. Grimmith
    Grimmith Samurai
    295
    288
    63
    Iowa
    Awesome! Thanks Easter!. Would you say there is a certain amount of time it can be upside down or laying at an angle? It won't " mess with the insides" will it? It doesn't really tell you this in the manual hahaha
  4. Ratranger
    Ratranger XS650 Junkie Top Contributor
    Having it upside down won't do anything as long as fluids are drained. If you don't drain things your likely to spill gas, and possibly have oil seep past the rings causing smoke on start up.
    Grimmith likes this.
  5. azman857
    azman857 '80 XS 650SG Rider XS650.com Supporter Top Contributor
    Engine oil will come out the breather.. No might about it.
  6. Machine
    Machine Race the wind Top Contributor
    Prolonged upside down position would put all the oil sump sludge on the now roof trying to drip with the oil. Down “UP” into your clean areas. I wouldn’t want that gritty sludge migrating towards the crankshaft and rods? Head?
    Are you going to disassemble the cases ? No concern then ..
    why are you inverting your engine ? Curious
    -RT
    MaxPete likes this.
  7. Grimmith
    Grimmith Samurai
    295
    288
    63
    Iowa
    I will definitely have it sit for a few days with all fluids draining out, it won't be upside down very long, more at an angle than 100% upside down. I need to just check clearance measurements for my oil catch pan on the race bike build. I also need to see if any other bolts down there need to be lock wired.
    gggGary likes this.
  8. kshansen
    kshansen XS650 Junkie Top Contributor
    883
    3,041
    243
    Is this engine running right now? If so just warn it up good and drain oil while hot and pull both drain plugs and let it sit say over night with plugs out. Also might suggest removing the cover for the sump oil filter and let that drain overnight too.
Share This Page
