Steven Simpson
Here is a photo. Red wire has power
Or plug cap or wire.If it doesn't fire, the coil is bad or you're not getting power to it.
Yeah.... that too.Or plug cap or wire.
Yes, a habit of touching leads and connections can definitely stand your hair on end if the juice is plentiful.Naeehh ..it can have importance if you touch the measuring point ..with the probes in different directions ...there is a battery inside the meter that drives current through the circuit ..and there can be electronics that stops current ..in one direction and not the other
on XS 650 the rectifier Diodes
But i suppose he is after your hands Touching the metal on the probe at the same time it is against the measuring point.( lower picture )
If that was a high current point say 220 V ..That voltage would hit you at the same time
You could get an instant Don King hairdo and landing on your backside with some smoke and fireworks.
And could go worse,
So besides affecting the value measured in this case it can be dangerous in other cases.
But having said that ..a quick measurement of resistance both ways ,,no finger against .. is quickly done
Right on. Make sure when using electronic ignitions not to lose ground. I made up alligator clip jumpers for this. Clip one end to the head and the other around the spark plug base.I’ll put fuses in line once I find my spark and I clean up the wiring. I am just looking to find spark right now
