Hello all you Yamaha experts. I own a 79 xs650 special. My son and I restored this bike from the ground up and made a cafe racer out of it a few years back. I did not rebuild engine but did take it down to the case and installed all new gaskets. She was a really bad leaker. She never has idle correctly. I replace the carbs with VM34's hoping that would help, bike did not change. My idle got worse. So bad that I thought I had a timing issue. Spitting back thru carbs and some back fire, I have adjusted cam chain. Went through the valves. Adjusted points per manual. and set up timing. Still no change. Getting very frustrated. Well I pulled the trigger and went all pamco electronic ignition with the e-advance. Guess what? bike still idles like crap. Bike's rpm's also take off on it's own. Revs so high have to just shut it down. I have check the intake for leaks. The Vm kit that sudco sent did not come with intake gaskets. I called them and ask if i should use some and they said no. I removed intake and found that the brand new intakes developed cracks and one looked like it had a melted spot in it. I installed gaskets and there was no change. I'm out of know how. I know this is long but i'm tring to give good description. So I'm hoping you experts can give me some more feed back.
