1. Dismiss Notice
  2. Dismiss Notice
    Dismiss Notice
Capacitor in batteryless system
Discussion in 'The Garage' started by Jthomas, Jul 12, 2019 at 11:29 AM.
  1. Jthomas
    Jthomas XS650 Enthusiast
    40
    23
    8
    USA
    easy question here
    Do I install the cap in series or parallel to my fuse block?
    CURRENTLY- I have it installed similar to a battery (parallel). The ground goes to frame, the + coming from generator to the + post on cap, and the + post on the cap runs to my fuse block. Same way you would have a battery installed.
    I will note. That running the bike without the cap made it run terrible, then the second I attached the cap, it was all good.
    (My ignition died recently, unsure if related to this)
    Now I’m starting to think maybe it should be ran in series?
    + coming from generator running INTO the + on cap. Then run the ground from - on cap to the + pole on my fuse block.
    My bike is wired very similar to this- except I don’t have fuses inline like this. I have an actual fuse block/power distribution. (My key is wired before the fuse block)
  2. XSLeo
    The cap should be wired the same as a battery.
    It replaces the battery so it should wire the same way.
  3. XSLeo
  4. Jthomas
    40
    23
    8
    USA
    Okay that’s how I have it currently.
    I was just questioning it because I wasn’t sure how much current/voltage buffering it had wired one way vs another.
    Thanks
Share This Page
