Carb & Exhaust blanking plates
I started with a little filter but it always got all oily. If you use one, don't put right on the housing above the carbs, it will make a mess all over the tops of them. Run a hose back or back and down. I switched to the power brake check valve and like that set-up much better. Simple, cheap, and no mess.
So which check valve do you use and do you also run a filter behind it?
I have the older 2 nipple breather so I use 2 hoses and 2 valves, one poised over each pod.
