Wes-712
XS 650 new bobber project
Crackling rolling off throttle or in the mid range. (short drag pipes with baffles). Going through hell sealing leaks over the last couple years, all gaskets etc. replaced and it still does it, although not as bad. So I went back to the manual on adjusting the snap ring on the main jet needles to a lower position in order to raise the needle a bit for mid range. And my needle doesn't have all of the notches.
If you look at the pic, (snap ring off) you can see one notch and a fat plastic washer as well as two smaller washers. Can I just add another washer to two to raise it up some and have the same affect? Or should I buy another needle in a different size (if they come in different sizes). I believe it says 05h14 or something like that. I can double check.
Any help appreciated. Been neglecting this bike a little, time to get it running perfect, or as close as i can with such short pipes.
