gurgh. I just had this "discussion" with someone who's running 145's. way. too. rich. "i'm fouling plugs" Put your jets back to stock and work from there. "i hesitate and die above 4500 rpm" <repeat> "it's running like crap" <repeat>
With wide open intake/exhaust, start 2 steps up (137.5 in this case) and go from there *with* John's adjustable needles and your adjustable needles all the way down (clip at top) on a BS34.
Then do a WOT test in 2nd from 3500. if you don't die before redline, move up a jet size. Repeat until you start choking at redline, then move back a main jet size. You can confirm the jet's too big by letting off the throttle a bit when it starts hesitating. This will lean the mixture out to a burnable ratio, so your engine will run, and can maintain RPM's and speed.
After you've got your main settled, start moving the needle up. This is more of a seat of the pants art (unless you have a dyno handy) to feel if there are flat spots (leanness) or hesitation (richness) in transition from 3500 -> redline. Move the needle up a notch, see if it feels better. Move it up another notch, see how it feels. If you think that it felt better down a notch, do that.
Then comes the pilot jet.go back to your stock +1 (45 in this case)and do a 1/2 throttle test from 2000 -> 4500 or so. See how it feels. Repeat as you did setting the needle, going up a jet size, see how it feels, back it off if the smaller felt better.
CV carbs are *very* easy to run rich, since the slide only comes up on vacuum, and the vacuum only makes them go all the way up when you're at WOT making it pull hard.
Temperatures go down with fuel richness as well.
