Carb slide doesn't go all the way down after installing Heiden Dyno Kit
cmills83
Santa Barbara, CA
I have an '80 with a set of bs34's and bought the Heiden Dyno Tune Needle & Jet Kit off Mikesxs.
http://www.mikesxs.net/parts/yamaha-xs650-dyno-tune-needle-jet-kit-for-bs-34
After installing it seems like the slides fall a bit slower but also don't go all the way down like they do with the stock needles. I tried changing out the needlejet's but that didn't seem to have an effect. Also, it seems the right side sits about 1/8" higher than the left. Will it be okay to run on the carbs as is or is there something I need to do or fix?
Thanks
Hi,
As I remember the needle plastic bushing has a pin that has to locate in a hole in the slide. If it doesn't, the needle won't sit straight and can hang up. You might want to pull the carb cover and check that.
