Carb sync through air barb?
John52
XS650 New Member
Pennsylvania
Hello I was wondering if it would work to sync the carbs using the air barbs? I think that’s what you call it (where the petcock vacuum hose connects) This is on a 79 XS650 with BS38. I accidentally bought the wrong 5mm adapter but it takes the 6mm. I switched to non vacuum petcocks previously so the barbs aren’t being used.
Yes, that's usually where you hook the manometer to, if you have those vacuum barbs. They only came on '78 and newer manifolds.
