Although I've not tried it, I think an original may be able to be repaired by putting a couple layers of shrink tubing on each end. Let it hang off slightly so it curls down over the end when shrunk. All the original has is a thin rubber coating and that seals fine. If you look in the hole in the carb, you'll see it has a beveled bottom. Forcing the rubber coated end of the tee into that bevel is what makes the seal.
