Hi all. I need help with right cylinder missing on idle. I have an 83 with bs34 all stock.The carbs are clean (3 times) and 3 pilot holes are spraying fine with aerosol carb cleaner, same for mix screw and choke plunger. Float is dead on at 22mm, pilot jet you can see through clearly, rubber plugs on, new float valves and synced . I have switched the coil wires , plugs , and mix screws with no difference, so i took both carb banks out and, fit the left bank on the right cylinder , it purrs. When on choke..both work fine, both spark plugs after idle are almost black with mix screw set at 3 turns out. After half hour drive .. both plugs are light gray with a medium brown at the tip of the porcelan. I have sprayed for air leaks with no difference and i like to do the dead cylinder test on the bad one, but it'll die when set at 1200rpm after 5 or 10 seconds. Sorry for the long post.. but by saying what i've done, it'll maybe point you at something i missed. If anyone can help..it's much appreciated. ps.. cam chain tension done, valve clearance done.
