JR Hammer
XS650 enthusiast
So my XS (2FO) got a little shitty gas the other day and the pilot circuit got fouled. You know the kind? popping at idle crappy noisy running engine at low throttle, snappety pop pop BANG... So I stripped the carbs down a blew out every orifice and all the jets with carb cleaner poked out the jets with a wire bristle, rinsed it all in carb cleaner a 2nd time then reassembled, balanced vacuum, installed filters inline with tank... Real nice.
Then I took it for a 30 mile cruise around town, I hammered on the throttle a few times and everything seemed good... So I rode to work next day and now it's doing something else. Seems to run fine up to around 3k rpm then it gets choppy and sputters or stumbles under hard acceleration. Same thing from a dead stop, if I am at about 1/2 turn on the throttle or more the engine sort of lurches, like it wants to spin hard but then it doesn't.
so I stripped the carbs again, and halfway through I wondered to myself, "Is this the carbs?? Or could it be the ignition??"
pamco ultimate with iridium plugs gapped at 030. #137.5 mains/#27.5 pilots. Stock headers cut down to about 30"
