Hi.
I recently rebuilt my carburetor, the main reason was to rejet. The previous owner fit non-stock exhausts and the sparkplugs were fouled with dry soot indicating that the motor was running rich. I adjusted the pilot and needle for low and mid, I did not adjust the main (yet). I ran some tests and the sparkplugs look good now, a nice clean burn with no blistering or fouling. However, there is a problem (There is always a problem ). The bike "races" when idle after it has warmed up. It will race until I put it in gear, at which point it settles somewhat.
I had a few guesses on what could be causing this. These are my guesses:
1. The clutch is slipping, I don't have a lot of evidence to support this. The bike doesn't creep when I put it in first and activate the clutch. However, it is very difficult to get the bike into neutral after it warms up.
2. The carburetor needs to be cleaned. I didn't use any cleaner when I rebuilt, I just used compressed air.
3. The mixture is too lean-- Would this cause the motor to race?
Has anyone had this sort of issue before? I don't mind getting my hands dirty here, and I love to learn.. so any hints would be great. And any guidance to tell me if I am on the right track or if I need to add any more things to my above list.
Thanks folks.
Thanks folks.
