Case studs
jakeroper
Australia
hey guys just fit my case studs and thought before I go any further I’d check if I should be using a thread locker on them or anti seize
Cheers!
For what it's worth, I use thread lock because that's what Mama Yama did at the factory. Mama's compound was pretty tough.
Thanks Griz I think I’ll pull them out clean them up and put some medium strength loctite on them. I hope it won’t make a nightmare for whoever pulls them out next time
Won't be a nightmare if Mr. Whoever knows what he's doing, Jake. Heat and tweak, heat and tweak, removal is a minor PITA, but you really don't want those studs backing out on you. Can't expect the studs to need pulling on a regular basis anyway--or so we hope!
