Ok, I've been chasing after a hanging high idle after a full rebuild '80 650 with BS34's. Carbs have been done, new boots, etc. I just replaced the shaft seals too. Spraying around boots and manifolds show no change. Shafts are good too now. However, I noticed that when I press down hard on the carb tops, the chrome part covering the slides, the idle dropped. I've not run into this before. Can air leak past the tops and lean out the idle circuit? I can't see any obvious issues with the slide diaphragms but didn't think air getting past the top would have an effect on the idle circuit.
Anyway, any ideas would be appreciated. Thanks!
