Hi peanut, I did do what you said. I pushed on the end of the right side carb shaft but it didn't have any effect. They do move a little bit left to right so not sure if that means anything. I agree, something is funky with these carbs. I've cleaned them a bunch of times and just did another solid cleaning. Everything blows through properly. Maybe the issue isn't the carbs at all and it's just manifesting itself as carb related. Maybe it's an electrical issue. I don't know. Here's what I can tell you:
If the carbs are in sync, it high idles. Turning the idle screw out will bring the idle down but once it starts coming down, then it's too low to idle properly. If I turn the sync screw counterclockwise, or out, then I can also bring the idle down while NOT having to mess with the idle adjuster. But then the right cylinder runs weaker than the left obviously since it's not getting the same flow. It will run and ride like this. Pretty good too once the rpms pick up. But, it still wants to try and idle high. I've sprayed around using the straw and sometimes that will bring the idle down but the area that causes the change seems to move around. At first, it was the right end shaft area. Then that stopped having an affect. Then, it was the left side inside shaft. It's crazy.
I've just got to get a different set of carbs on this thing to determine once and for all if it's carb, or something else causing all this...
I appreciate everyone's help. This has been a real booger.
